Better coloring in Show Samples in Image Samplers
Hi.
When optimizing image sampler settings, its not easy to see where the DMC Sampler was forced to keep the pixel “as is”. I suggest an option for “better visibility”. This means, if you have a range from 1 to 8 samples, 1 sample should be green, while 8 samples should be red.
Alternatively it would be already helpful if (instead of just many blue gradients) I could see red pixels where the sampler would have taken more pixels if available.
I haven’t found such options in VRay yet.
Should not be too hard to do this (for the Adaptive DMC sampler at any rate); I will log this as a wish.
I quote it and I suggest to have the infos picker can pick the different AA subdiv… now it read only the rgb infos of the image
yeeessss, I remember an old request of mine about this issue, please add it :slight_smile:
