Big Nasty bug using DR+Batch render+Scene states
Hi, i have a nasty one here, Left the pc rendering some images over night just to find this thing
as you can see the “oficinas” was the first image rendered, and “cafeteria, sala de juntas” were next.
I really want to know how to fix it or if it will be checked
SO??? is it a bug?, im doing something wrong or what??
On another post were i put a bug i didnt get a response either, if im doing something wrong i will love to know, really love the software and more than sure im buying the license (in part to get more technical support in this cases) the batch render process is really important to me (just setup the images and leave them over night… no supervision etc…)
This was posted multiple times before, it is a known problem. I usually go through bugs after I have finished features for new version. I just cannot do it immediately, or I would not have enough time to implement anything new (I cannot just switch between bugfixing and implementing, both need undivided attention and concentration over several days)
Clearly, some sort of cloning technology is needed here. :smiley:
About blending images, I had a problem. The problem was solved when I changed the Corona VFB on the Standard Native 3dsMax VFB. However, this does not always work. :frowning:
Ok, so any one had some other work arround for this??
Duplicate: Overlappin pictures in distributed rendering with batch render - Corona for 3ds Max :: Issues - Chaos Forum
