Hi, I have a very simple scene with a cube that changes height throughout an animation, from being rather flat rectangle and then transforms into a square. Its just a normal Box with the height parameter changed over time. But, I have a edit poly modifier on top that changes its autosmooth on top of this animation. When I play this animation in the viewport it plays fine (!), if I put on a grey material and render with Scanline it renders fine. But with Corona it takes like 5 minutes for every frame, it says “transforming vertices” before it starts rendering. So even though each frame takes about 30 seconds to render, it still takes 5-6 minutes for each frame because Corona isn’t able to start the render. If I remove the Edit poly modifier, it renders instantly!. Also I tried adding a smooth modifier instead, it renders faster but still takes a lot of time compared to whats normal.
I tried with the current 1.7 build and the 2.0 RC3 build, same problem with both!
I can send you the scene if that would help pinpoint whats causing this, but its a commissioned job, so I have to send it directly to someone.
