I have complex scene and I hide unseen objects to keep the memory usage low. But now my client want to get panorama views and I need to show all objects at the same time. I did a first test and enabled all objects. But now objects of the scene are invisible at the rendering, it looks like random objects are not loaded. What can I do? In CPU mode all objects are visible and the scene looks good.
I found that it works in RTX mode and is using only ~4GB at my render-only GPU. So, It’s not a question of the memory. I will send a bug report per email. ( #16268 )
Your scene is successfully delivered.
I confirm that there is a difference in CUDA - CPU/RTX results.
Will discuss with @Muhammed_Hamed and the dedicated teams and keep you up to date what is happening.
Thank you for reporting.
Please confirm with which V-Ray version was the project started or are there any objects that may come from projects where old V-Ray versions are used.
This is important to exclude Migration issues.
The project was started in may/june per Rhino7|VfR5. I checked the material list now and found some materials which are looking like VfR4 materials exported from the disk. (.Stoff.xx)
I got all 3D-models from my client, but he doesn’t use V-Ray.
