Spare time personal project based on Zanderroth Architekten’s project named BIGyard.
I’ve just imagined a different context and I had fun playing with 2 different moods and lighting setups. Most enjoyable part has been painting the road texture, blending several textures with custom brushes, in a single huge 60k texture with all the correspondent maps.
It’s also the first project done with Corona 3.0 and I have to say the displacement has been improved quite a bit.
Full hi-res set of images on my Behance profile:
There is something wrong with scale of several elements though - pavement texture, cars( or maybe it is the camera ) and probably people( especially those situated in the terraces) , hence building looks small.
It could be that the windows height give wrong impression - they look 2 m .
Nevertheless such pavement tiles/bricks usually do not exceed 20-24 cm( 8 - 12 inches). Probably they need to be scaled down, approximately 10-20% - use the curb for reference.
Interiors will benefit from better looking bricks - displacement, more complex shader with some reflections here and there.
Also floor looks bit plastic and pay attention to gaps - do not understand this trendy approach of exaggerated gaps - usually 1-3 mm work well, plus chamfer of boards around a fraction of mm.
Thanks for your feedback.
As said before, unfortunately those are the measurements of the actual building. I spent a bit of time in the beginning making my head around them, because it does look quite small, but that was probably part of the architect intentions or due to limited funds for a social house project. You can see the original one here:
Pavements are from 3d scans with accurate measurements, which exclude them being too big. Same thing for the cars or the people, so it’s actually the building giving you the wrong impression. The windows are about 2 m high, according to the project plans.
I’m not fully happy with the bricks a well, but they do have displacement coming from a 3d scan. I would have probably had to exaggerate the effect.
The floor is a real product and you can check the in situ looking here:
The originals does not have that scale feeling, mostly due to the shots taken from further distance and proper composition.
If pavement is from libraries, then would blame the camera angles and compositions as main culprits.
The clipped cars/people and the imbalance between pavement/street/building/void gives wrong sense of dimensions and scale.
Do not mean to be rude, but it does look like there is scale - related issue and pavement looks big in few of the views.
PS: Understand that You are not trying to replicate building and site 1:1 , but pay attention to car direction
No worries mate, I appreciate you’re trying to give your feedback, you don’t sound rude, but I disagree with you.
They are not comparable, because it’s way farer than where I am with the camera, hence the camera distortions are nullified in the original one.
One of the main point of the shots was to adapt the building in a standard road size context, so the shots are taken from the other side of the sidewalk.
The pavement, once again, is based on real world sizes and obviously looks overstretched on the portions nearer the camera, due to a wide lens. That would have happened in reality with a photographer shooting in situ.
Believe you are comparing them. I am using the original as a reference.
What point out is the strange scale issues related thing, which you seem to agree, whereas pointing out that it is either the 3d photoscanned texture or the camera lenses. Maybe you should focus first on this aspect of work. Overall nice foggy ambience, which could be executed better.
Use what you currently have as a scene to progress quicker as an artist.
Sorry man, I’m struggling to understand your English sometimes, but I got the overall point.
As mentioned before, I had troubles in the beginning working around the plans I’ve found online, because some of the measurements were off, but I’ve decided to stick to them in order to replicate an ideal commercial environment in which, obviously, you don’t have any room to change an architect design in a late stage. Consider also, as I know from my architect experience, what you usually find online are the final projects drafts, never the executive ones, so the actual built architecture is always different.
I decided in the end to thin a bit the pillars, in order to give a touch more breathing room to the windows, due to the building being too much heavy according to my taste, and change some finishings, to give a higher end look. Something that would have been impossible in real life.
The point of the artwork was to give a quite boring low-cost building a better look, in a more vibrant and tight urban context. It was less about the architecture, more about the atmosphere, obviously sticking to my way of working, which is maximum realism possible in a 90% 3d workflow.
With that been said, I work to improve myself everytime and there’s along way to go, so constructive critics are welcome and I appreciate your feedback, but I’m free to disagree if I find them pointless.
I will not delve further, since there is nothing much to be said if someone relates to advices as pointless.
Two people, and both of us have mentioned scale related advices.
Work more on composition, camera, object situation with stronger concept behind doing project than “photorealism”.
PS. Personally do not find the original building and site to look as you describe it, but guess it is useless to share opinion.
Good luck with future projects.
Alright, I’ll try for the last time, then I’ll give up.
We discussed extensively about the scale problem and as it has been explained to you several time, but you keep banging on it. Everything in the scene is based on real scale sizes, except for the building that has been modeled according to the architect plans found online. I can’t do much about it and I’ve explained it extensively. The thing that is deceiving your eyes is probably the people on the balconies, that are not supposed to be there in the real project, standing on a raised level compared to the actual floor level. I’ve imagined a step inside the room that would have given you access to that, as it’s not clear from the plans.
Your opinion is valuable but, as the word itself explains, it’s your opinion, so I’m free to disagree with it.
I personally can’t stand seeing any house in the forest or scandi apartment anymore, but if this is what people like to portrait and enjoy doing, why should I go and tell them focus on something else? Hence, if I like to focus on photorealism on my spare time, after working on commercial projects according to the clients taste during working hours, why should I be bothered?
Last thing, a personal advice but feel free to ignore it, as this is my opinion. Your attitude and your portfolio don’t really help you to make your critics believable. You started from the scale of the building and you went on several grounds, contesting basically everything in the shots, which would have been alright if shared with a different attitude and a top notch portfolio, but I’m afraid you are quite far from that.
You mentioned the bricks, that to be honest is one of the thing that should have been executed better, but, forgive me if I’m too direct, I see things that have been executed quite bad in your recent projects (see the screenshots).
Without even mentioning the lighting, quite awkward if done by someone of your experience.
In any case, if you want to develop this conversation, we can do it in PM. I think people are quite bored to read us going on like that.
Changes made: removed pictures, by owner’s request
Man… You went way too far in this. Sit down, chill out and do good, rather than to take it to that personal level.
What I kept mentioning is that there are several objects which give wrong impression of size/space/volume/void and advised You to keep on working on the aspect of composition.
Your last post basically says that If somebody else, who You respect and admire, mentioned all this You will agree.
Do not know if You are that arrogant by nature, or You are going through some serious burn out currently.
Your last post has been reported to moderators, since none of the stuff You use is supposed to be posted here, moreoever there is copyright infridgement.
PS. BTW what’s up with the portfolio You refer to? I do not mind developing conversation, but find Your attitude way outside the humble zone.
I removed the pictures from Hadi’s post, but left the message itself - i don’t find it to aggressive or inappropriate. Nevertheless, i’d suggest to calm down to both sides. Keep it civil.
Hey synolog, no you’re right.
I’ve explained extensively that the building should have been bigger, most likely according to what you have drawn, but this is what the section found online, scaled accordingly in Autocad, gave me back (check screenshot).
Those extra 30cm in height would have been much needed indeed.
I don’t know if they changed it in the executive plans.
