Bitmap error, failed to allocate filter tables
We have been seeing this lately and I have been unable to pin it down
outside of course of there not being enough memory.
What seems odd is that we have never had this issue before (before I
suppose the past few months) and it seems to be random.
One frame may throw this error but the next one does not on
the same box, any guesses.
On server new: \\192.100.100.7\maps\Flythrough\Landscape\MULCH.jpg -- Failed to allocate filter tables for this bitmap. Not enough memory. This bitmap may render incorrectly. Subsequent errors will not be reported.
The map above for example renders fine in other files and in other frames
but it looks like as stated above to be random.
Most of the machines encountering this errors range in hardware
from Dual 3.06 Xeons to Dual Core x64 4600’s all with no less than 2GB
RAM and plenty-o-virtual and drive space.
do you have your bitmap pager turned on?
this happens when you run out of memory…bitmap pager should do the trick usually. just do a quick calc how big just a few maps get when in memory (in memory it aint a jpg anymore, but uncompressed)
Thorsten
will go back and check it thanks
