Hello everyone!
I’m facing an issue with Corona Render. It’s not showing the Bitmap on the object in viewport. It only shows when I connect directly to the Base Color.
When I put UVW Randomizer or Corona Multi Map doesn’t show anything. And to be clear: I’m not talking about show the randomized map and every other “effect” directly on to viewport, I’m talking about just the map.
When I click with the right mouse button over the image, the option “Show Shaded Material in Viewport” doesn’t even get the “tick”.
In fact, I’m facing this issue with the Material Editor button called “Show Shaded Material in Viewport”, it doesn’t work properly anymore like it used to.
I’m attaching two images: one with bitmap connected directly in Base Color and another with the Randomizer and MultiMap.
Thanks in advance to everyone!
