Bitmap2material
I use a map substance. All maps are generated except the maps of specular and glossiness. What’s the problem?
http://view.xscreenshot.com/67b63661b9cf56198af774d837f39161
Substances works fine with Corona AFAIK. Does that particular map works as expected with other render engines (Mental Ray or Vray)?
with vray doesnt work too
the problem in substance?
Not sure. In max 2014 substance map looks very different than in your example. What max version this is?
2016 version
Hey Neph, not sure if you still needed help with this but the solution is to change the maps you’re wanting to use from 0 to 1. That will turn the output ‘on’.
