Single frames have black areas in a long movie clip. It is always the same frame (no matter which computer). When all light sources are off, these black areas disappear. Shadows can not be the cause (see pictures). Unfortunately we have the phenomenon with many clips
Hi there, I have seen your ticket and have responded. I look forward to hearing from you. ![]()
Please report if you find the bug, i had this also in one of my last project and could not figure it out…
Here is the solution from the corona team:
Your only option is to change the light solver from anything other than “auto”. See the attached image. You will need to find what works best for you but keep in mind that this may increase the render times.
Hi Volker!
Have you tried the newest daily build? (3.2)
