Black box appears when rendering vray 5 for sketchup. If you apply the V-Ray library material, a more severe black box appears, and if you proceed with the rendering as it is, SketchUp will also be forcibly terminated.
HI @changhwan_kim ,
Is it possible to forward us that project so we can see if we’re able to reproduce any issues? Make sure to mention this thread in the form subject.
Moreover, please also share details regarding your OS/CPU/GPU/driver version. Much appreciated!
Hello nikoleta.garkova
You seem to have found the cause.
Because it was a problem with the cpu renderer, the cpu was overclocked, so I applied a little more voltage and the problem did not occur.
Thank you for your efforts to find the cause.
I love v-ray
Hi changhwan_kim,
This is the first time I’m hearing about such problems.
Please let us know if you experience the issue again.
Regards,
Konstantin
