Hey!
Tried rendering 400 frames of an animation today with additional cryptomatte element with material name method, but ran into a problem regarding it’s output. So, whenever I render stuff in VFB, it properly ‘calculates’ and displays the cryptomatte pass which is great, but whenever I try to save it (from VFB/regular render from Render settings) to a multi-layered EXR, it never happens to work - it separates into 4 different channels (VrayCryptomatte, VrayCryptomatte00, VrayCryptomatte01, VrayCryptomatte02), and just one of them have any information - which is basically some weird outline around random object, the rest of it/them is pitch black.
What I already tried doing:
- thought my scene is broken → fresh scene with simple geo setup - doesn’t work
- regular rendering ‘pipeline’ > adding Render elements, pressing Render > it always renders just the beauty pass in the .exr file, without any additional pass,
- saving straight from VFB (and even if it worked it wouldn’t pass for me, I need 400 frames) > Cryptomatte shows up perfect in VFB > after saving into a separate file from VFB is pitch black in AE
- saving Vray Raw image file exr > that one contains the passes (opposite to Common tab > Save file from Max - that one saves just the beauty channel, never contains anything else) but the cryptomatte is again broken
- adding VrayOptionRE element with EXR multipart ticked on, doesn’t work either
Sadly cannot show the whole frame, but here is the same fragment:
VFB:
AE:
Layers list from Extractor:
Do you guys have any idea what could be happening? I am using latest build.
Cheers and thank you,
Filip
