Good morning.
I rendered out a lots of views last night to find this on all of them.
Any idea?
Thank you
philip
Hi, which version exactly is this?
Could you upload the scene for us? Chaos
That’s so weird… The same I got last week but never happened to me again and I can’t replicate the problem for now.
Dionysios -
those are NaNs, easily fixable, but we need to scene where it happens
I sent the scene this morning about 7:30am.
can you send the scene with textures? It does not happen here without them…
I used resource collector in Max and the textures should be all in the zip file?
there is just .max file in the archive (Kitchen-Mode-02.ZIP - is this the correct arhcive?)
3ds collects not all texture, use this script http://www.scriptspot.com/3ds-max/scripts/collect-asset
Thank you
I have used the script, and the I have resubmitted it .
So thank you very much.
I hope it is a simple fix .
Regards
phil
(I could not locate the archive with textures, so I requested it again. This issue is being discussed in support ticket #8472)
hi,
is this still happening? If so, have you uplaoded the scene?
In the support ticket, I did not get any further message from Philip after I sent him a link to the build which contained a fix for this. So I assume we can close this.
Link to the scene with textures is in our internal tracker under “8472”.
