After switching to R8 for my tests i get unclamped GBuffers now. i compose them all together now and pretty much got every friggin single channel done now. The only problem i’m left with is black edges on refractive and reflective objects. I’ve created a comparison image to show it. To the left you see my final comp. The middle is RGB Element the right is unclamped RGB.
As you can see both the reflective and refractive objects get pronounced black edges. This is even more appearant in this pic as also reflection filter and refraction filter were used. I multiplied them with the corresponding reflection/refraction channels. is that right at all ? The edges are also visible without the filter tho.
Multiplying render elements is not a good idea as it can lead to edge artifacts. The only correct operation that you can do with two render elements is to add them (even though V-Ray provides render elements that could be multiplied). Further on, you should not use color mapping other than linear. Also, what program did you use to combine the elements? And what antialiasing filter?
AA was set to Adaptive Subdivision at 1/3 with and without outline checkbox. What is the correct transfer mode to combine raw reflection and reflection filter then ? as adding them gives pure white on full reflective materials so that cant be right in that case, can it ? I used nuke to comp it all together.
What is the correct transfer mode to combine raw reflection and reflection filter then?Multiplication, of course. But like I said, multiplying elements is not a good idea (you will get to edge artifacts sooner or later). It might be better to use the normal reflection element instead, and add that to the final result.
sorry got you wrong there…AA filter was set to cubic. When using the Reflection element instead i got the filter already calced in, can i get it out by reverse multiplying the filter ? Bothers me a lil as i’d like to be able to tweal falloffs a bit in post wich would work fine when using the filter and grading it.
i just tried adding the reflection and refraction elements, and they also result in black edges. not as strong as wit raw reflection and filter, but still clearly visible and different from the RGB channel
Here’s a difference image of the rendered RGB Element and the final comping. The only problems are on he horizon (that’s prolly because of the vrayplane, right ?) and on the edges of reflective and refractive object…everything else seems perfect.
I know it’s a simple scene, but can you send it to me at vlado@chaosgroup.com for more detailed inspection? I’m out of ideas what may be wrong until I play with it
Why?
you could use the vraysky, or whatever you use, as a vray enviromental override. I meant just the max env. background.
curious if that works in your case.
i have sent you the latest version. i tried area, cubic and the two new vray ones. And making environment black doesnt make it any better Joost. Am running out of ideas here. Am trying a diff scene now just to have a bit of a change lol
Here are my results using the Area AA filter; additionally I’ve rendered to .png files (don’t have Nuke here to work with .exr’s). These are the only changes I made to the scene. Also I used Corel PhotoPaint for the compositing. I’ve added the following elements together:
specular
caustics
background
global illumination
lighting
refraction
reflection
Here is the comp’ed result:
Here is the original render:
Here is the difference of the two:
As you can see the difference is negligible. I don’t know what exactly is wrong with the process you are using though. It might have something to do with Nuke and what it does to images, but I wouldn’t know for sure (your results seem brighter for some reason, both the composition and the original render, maybe there is some hidden gamma correction happening along the way??)
The brightness difference was easily fixed…didnt notice it before tho. That changed by switching all nodes to sRGB mode. Still black edges tho…and the strory continues
i’m running out of ideas. tried to comp png’s as i thought it might be some stupidity in the EXR IO…same prob…will try in PS now…wonder why it worked for you vlado…btw. did you save 32bpp pngs or that 48pp ? maybe it’s the clamping that makes it work ?
If all else fails, you can use the VRayCompTex to combine the elements in 3dsmax, that is guaranteed to work (see this for some examples: Chaos: Industry-leading design and visualization software and note that VRayCompTex is now a part of V-Ray so no need to download that).
