black render or crash when using ExtraTex
With the attached file, when I add the ExtraTex render element to the scene and try to render command line (i.e. render farm), I either get a black frame or Nuke crashes.
When I render in the GUI it works fine.
Can you check it out please?
Cheers,
frank
render_crash.nk.zip (3.14 KB)
Hey,
Sorry for the late answer.
This should be fixed in the nightly builds.
Great, thanks! Can you tell me what caused it? Cause I have used ExtraTex nodes successfully in a different setup recently.
It was an internal V-Ray issue. If something else comes up let us know :slight_smile:
