black spots - not render at all
black spots - not render at all still apear on my render:(
this is the colmplete image after rendering, and some places are just not rendered, can u help me?
reneder in VFS7 01.05.30, the image is only 960x516pix, my machine is: coreI7, 6gb ram, winXP 64
Re: black spots - not render at all
Distributed Rendering?
Rendering is not distributed, just single computer.
I use sketchup 7.1, vray 01.05.30.
I’ve had this. It seems that some of your ‘cores’ are running out of memory. In my case I reduced the size of the buckets (the ‘region division’ in ‘system’ settings).
I was using 128 and I reduced it to 64 and it fixed the problem. (I am assuming you are using a multicore machine).
David
I had those issues in the past on busy areas in renders, around leaves of trees or tight repeating pattern areas.
In past versions of Vray, I would make sure to hit the screen size ratio button on the output flyout section. So choose your output size and then hit the screen ration button. That seemed to stop that from happening most of the time.
In the most recent version, I tried changing the region size as dcauldwell suggests. That did work as well, maybe more consistently, even when not setting output to the screen’s ratio.
Reducing the size of the buckets solves the problem, thx for your help:)
