Blackout screens when rendering on Medium and higher mode/ Cuda and RTX _VRAY for Skecthup 2021
Today, 07:13 AM
Hi Team - can you please help me.
I have two GPU’s RTX 3080. Tuff and Zotac Gaming.
I have experienced numerus blackout screens when rending with RTX mode. Also tried Cuda mode but can not set higher then Low+ when rendering. If the setting is higher after a couple of mins my screens goes black. I can still hear the GPU’s render and PC running in background but my screens are black.
I tried to problem solved by checking cables/ updating graphics drivers / updating windows/ deleting NVidia cache files/ updating DirectX and monitoring the temp of the GPUs to see if it goes higher then 100 degrees. It does reach about 87 degrees. Fans work at 100% and there is enough power supply.
Please assist. Have you come across this issue before?
Very difficult to finish projects on time.
Vary 5.20.06
CPu 10900K 3.70Ghz
64 GB
Windows 10 Pro
Thank you.
