I am having this issue with my file…
No matter what view i set it to, the rendered image always comes out the same. Blank with a bright sun spot ( It seems )
I have copied and pasted to a new file and still nothing…
Any idea? I checked the settings, and even defaulted them.
Thanks! Have not posted in a while, things have been really busy.
Thanks!
-Gallystops-
Re: Blank rendered image . No matter the view
error log give you any clues?
to my knowledge this is normal, right?
I do not get a warning or anything..it renders each time no problems…but it renders it just as i showed before…
C:\ProgramData\ASGVIS\Python26\Lib\site-packages\Ft\Xml\InputSource.py:346: DeprecationWarning: functions overriding warnings.showwarning() must support the ‘line’ argument
FtWarning, 2)
FtWarning: Creation of InputSource without a URI
is that what the error log says after SketchUp has been closed? That stuff is just normal warning messages that exists in all error logs. Also, this is .89 you’re using, correct?
.90
Sorry i should have said earlier.
Yes there is no other stuff in the error log.
.90? hmm… didn’t like the latest beta?
I have not even thought about it to be honest. I have been SO SO Busy! Non stop work i would hate for all my work to then get messed up some how. which im sure they probably wouldnt. Just i want to be safe until i get some time to update.
if you want to submit a beta bug report and attach the scene file, I could try to take a look at it this week, see if it renders correctly in the current beta.
i will try it on my computer at home with the more up to date version. And i will get back to you tomorrow.
thanks Dk
-Gallystops-
updated to .99.
all is normal again, thanks
-Gallystops-
WHEW! Glad to hear it! You had me scared for a bit there. Happy Rendering!
