I just loaded up one scene, pressed F10 and wtf’d.
I thought this might be because my pc died last night while rendering this scene and file might be corrupt, so I loaded previous version of this scene (I often save and increment as mommy says) but the same thing happens. This doesn’t happen for every scene from previous versions, just a few newer files. I’ll try to figure out what’s the difference between the files that work correct and those which don’t. As for now my guess is only there are more lights in newer scenes. Any ideas?
Also, pressing F9 crashes max.
Is there a way to change active renderer from max script level and reload it?
Sorry to say but after moving all the dlls and plugins to a temporary folder now all the windows look ok. There is just “missing renderer” title and some missing files warning when opening.
Yup, after switching to scanline everything went back to normal. Now I can load Corona again and be happy. Thanks DeadClown!
But on the other hand it might not be a bad idea to reinstall max.
