Blend and Vray 2 sided material.
Since a lot of material libraries use vray 2sided materials and vray blend material, i think there is immediate need for its support.
I hope we can soon this be implemented.
Thank You
Hey @vishwanath_mani
Could you please explain the use case for this setup here?
The V-Ray material has a Thin-walled mode in update 1 and 2, which can simulate thin translucent surfaces like paper or leaves(similar to how the 2-sided material works).
The new workflow could be used in a blend, if you explain the use case and attach some reference images, this will be helpful
Best,
Muhammed
Thanks you for help.
Mainly I want to know hoe you use it for sheer curtains and lamp shades.
