Blend landscape to road
I’m not sure if this something that V-Ray can do or not.
Is there a way to blend the landscape mesh to the road mesh?
I’ve tried using a V-Ray blend material and a ramp in the blend amount but there are still harsh borders between the two borders.​
Depending on the situation I use a Round Edges node. with a blend material.
https://forums.autodesk.com/t5/maya-…t/m-p/11646469
Thanks damaggio!
That pointed me in the right direction.
Just had to play with the ramp and the UVs of the road. I will play with the round edges and see what else I get.​
