Blend Material Bug
Create a blend material
put the blend material itself in the base slot
cinema crashes (R21)
If you try to open the crashed file, it crashes again.
only removing vray from the plugin list and deleting the material, fixes that loop.
You can turn off material previews update from the preferences, maybe that would help to avoid the crash without uninstalling the software. Why do you want to put a blend material in itself? Unless you do that by mistake it sounds like a really bad idea;)
Because if you open the crashed file, you cant do anything and c4d will crash again.
Hello @folklore I managed to reproduce the Freeze on my machine. I will discuss it further with the team.
Could you please let us know why would you want to put the V-Ray Blend material in one of its slots? Or perhaps you made it by mistake?
was by mistake
The issue has been logged in our system [VC4D-2029]. We will contact you if the matter is further developed.
Hello @folklore ,
As you might have already seen in the Announcements section, we just released V-Ray 6 for Cinema4D, Update 2. With it, we introduced many new features and improvements, along with numerous bug fixes. Please note that the bug with the Blend material, discussed above has now been fixed. You can download the latest builds from here. I hope you will enjoy the new features!​​
