Hi everyone.
Have found a bug in standard blend material.
Bump map applied only to one of them, but renders on both.
Is it possible to fix it?
Volden, are you sure you are loading the mask bitmap without gamma correction??
Where can I check this option?
Hi. I got some solution for this problem.
Thanks. It was not so easy as I supposed, first time using Blend inside Corona///
I haven`t that menu option O_O
But I always use gamma 2.2
By the way, blend mask was Gradient ramp
this is currently a feature, I don’t know if it will ever change
