Blend Material in Max 2017??
Hi there,
I just installed Vray 3.4 for Max 2017 and I’m surprised to find out that Max doesn’t not show the Blend Material when vray is installed.
I would love to know if this is intentional or just a bug.
Any info on that?
Thanks.
It is intentional. You can turn on the “Show incompatible” option in the material/map browser to make the Blend material to show. However keep in mind that the Blend material slows V-Ray down; it is better to use the VRayBlendMtl instead.
Thanks Vlado!
Yes, I know about that regular Blend slows Max down but I have have a large library based on those shaders. I’m in the process of rebuilding the Library from scratch using Vray Blend.
It should be pretty straightforward-scriptable if I’m not missing something here, the conversion process. Also something the VRaySceneconverter could do in the future :smile:
Yep, how many scenes are the materials in Fausto? There’s been a tonne of utilities to convert back and forth between various vray compatible maps and not so the code is floating around in many guises.
