Blend material
There is new material in Corona.
How can I use it? It’s a kind of new way to make material like in R16 with reflectance chanel?
No, it has nothing to do with the Reflectance material in R16. The Corona Blend material is for you to blend materials. As simple as that!
Here you have one of the possible uses for the Blend material: https://coronarenderer.freshdesk.com/support/solutions/articles/5000516191-how-to-create-carpaint-shader-in-corona-
Ok I understand Thank you
Do I need blend material to make gold?
It’s really hard with corona materail. There is some tutorial for C4D? To explain how to make realistic material?
