Just recently had all my nodes crashing (using Pulze render manager, scene manager, max 2022 and latest DB of Corona 8.) Tracked down the crash to a render element with an asterisk * in it. It was created because lightmix auto setup (which we often quickly use for Draft 1 images) grabbed a layer name that had a light material assigned to it which the architect had named with a ‘*’ in the title.
Couple of hours later and we solved it. But might be worth blocking Lightmix setup wizard from using any characters that’ll cause this kind of crash.
On a second thought, I am not sure if it makes sense for LightMix to detect illegal characters.
LightMix render elements are named after each object. If an object name includes some illegal character, a render element with this name will be created.
At the same time, the user can always rename a render element to include illegal characters, so this is not specifically a LightMix issue.
When this happens, 3ds Max should show a warning (attached) and this warning should be included in the log files.
I will log this as a more general issue (not only related to LightMix).
