So I may have a scene that I’m using for testing that seems to render NaN pixels occasionally. Bloom and Glare will turn completely black even if only one NaN pixel is present in the VFB.
Where/how to upload?
Scene uploaded to Dropbox since filesize exceeded 256 MB, filename is ‘Coron_1.5.1_Office_Night.rar’… forgot an ‘a’ there.
There were several issues with the file, including reproducible crashes:
Never had any crashes when rendering on a single machine. NaN pixels occured in the past regardless of DR or single machine rendering.
Hope you’ll be able to track down the issues, contact me if you need more info or anything else: mgmswee.net or through PM here.
Is it similar to this problem? Bloom-Glare bug - Corona for 3ds Max :: Issues - Chaos Forum
Anyway, Ondra is already investigating the NaN issue.
I don’t think so, as far as I can tell B&G will produce a black image with NaNs. Then again, my knowledge of the internals is limited…
Should be fixed, try the next daily when it is out
Thanks, will test!
Is this fixed in 1.5. hotfix 2 or only in new dailies?
I believe it’s the next daily, but it probably won’t hurt to test hotfix 2 too. ![]()
I’m asking because the fixes for hotfix 2 looked like they were exactly the issues I have posted above. If they’re not there’s no point in testing, if they are I would test to confirm.
this fix was actually simple enough to do it in hotfix 2, so go ahead and test it! ![]()
So, just tested with 1.5.2 and unfortunately I’m getting exactly the same problem - NaN pixel(s) > Bloom&Glare black result. It didn’t crash yet when collecting data from DR servers but it didn’t crash every time back then so chances are it still may crash, only not regularly.
Ondra, in the scene I sent you the NaN pixels will always appear on that picture on the wall. It’s either the glass or the object behind or a combination of both that will produce them.
ok, this was actually a separate bug with exactly the same result. I fixed this one as well
Great, thanks! Will the fix be in the next daily? I would test again just to be sure…
yes, but the daily will be after corona academy… contact me on skype to get the build sooner
I don’t think I got your skype contact, could you PM it to me? Thanks!
