Bloom and Glare pass sometimes doesn't save
Hi guys,
I am now rendering animation. I save passes such as LightMix, bloom and glare. The bloom and glare effect was displayed in approximately 50% of the images, but it was frequently saved as a black image, so it essentially disappeared. Of course, it was also missed in the Beauty Pass. When I checked the camera settings, I saw that the Bloom and Glare attribute fields, such as OVERRIDE and ENABLE EFFECT, were ticked. I’m not 100% sure, but it appears that sometimes the Bloom and Glare effects were turned off automatically in the VFB window when I open the VFB window.
Did anyone have that experience?
Thank you for replying.
Hi there,
Could you please let me know what your C4D and Corona versions are? (the entire version number, please)
OTOH, is this happening with every single file you’re working on? Or is it happening with a specific scene project?
Are you using the C4D’s Take system?
If not, could you please describe your workflow a little bit more?
Please consider you can always submit a support ticket if you want to keep some of the info private (I mean, between you and us)
Looking forward to hearing from you soon.
