Is it a default setting to add bloom and glare to the render element passes such as Reflect and Emission passes?
We shipped a scene to render yesterday and when it came back, we found bloom and glare on our reflect and emission render elements, despite us rendering out the bloom and glare as a separate render element.
Bloom and glare is basically a post effect so should it even be present in the essential render elements? Or is it a bug?
Also be aware that post-production in VFB affects Glare and Bloom pass. Esp. LUT can drastically change the pass which no longer can be composited correctly in post-production.
Here is workaround I currently do: I render with G&B pass, this pass is only ‘full’ if the effect is turned on in VFB. When I finish the render, I save all passes + beauty with effect OFF and post-production ON. Then I turn post-production OFF and turn effect ON and save B&G pass separately.
