Hello everyone, i’m currently new at Corona for Cinema 4D, and i’m trying to solve a issue but i can’t seem to find a proper solution.
Im doing a animation and i need to use alpha for compositing later in After Effects, the problem is that the Alpha Channel takes away the Bloom and Glare options, it only aplies if it is on black background or has pixel in it.
The ideal solution would by having a Bloom and Glare pass on the multi-pass option, but as i was reading the FAQ for Cinema4d, the Pass for Bloom and Glare was working before, and now it doesn’t work anymore. [Atached a screenshot to show the post]
I was just wondering if i can get around that, try to reproduce Bloom and Glare in a different way, or extract the Bloom by darken in all the scene and use the Add or Screen for Blending mode in After Effects
In the 3ds Max version the solution would be to render:
-beauty without bloom and glare, with alpha
-bloom and glare pass (the effect is stored on black background)
Then place the bloom and glare pass on top of the beauty.
Just did a little “trick”. Saved image with ‘Bloom and Glare’, and the second one without it. Then in PS I mixed layers with “Difference” option. That way I got a ‘Bloom and Glare’ pass. Now you just need to put it on top of an image without ‘Bloom and Glare’ as ‘Linear Dodge (Add)’.
