Bloom & Glare in 360 Pano issue
Is the attached image displaying expected behaviour for bloom and glare in a 360 spherical image?
I cant tell if its a bug or just the projection messing with me.
Thing is, that doesn’t look like a 360 spherical, all the lines are still straight :smiley: Everything should be distorted due to the spherical mapping of the camera.
Ive set the corona camera to 360 spherical. This is a very small snippet of the image (10000x5000)
Aha - well the bloom & glare shouldn’t look like that, as far as I can tell - you can see how it should look in my image, doesn’t seem the same as what you are seeing. Any chance of sharing the scene? I was using B&G in the VFB, were you using it in the camera settings?
I used the VFB but is it possible that it was applied in both the camera by default and then the vfb?
I can share the scene. Should i make a mantis submission?
You can send the scene by private uploader (Chaos) and I can take a look, not sure if it’s a bug or not yet - if it is, I can add it to the internal tracker. Probably easier than creating a whole Mantis for it to upload the scene, but if you do go that route, let me know and I can head over there to grab the scene!
Cheers!
