Bloom won't stay off for animaiton
I’m using 3dsmax 2025, Vray 7, Vantage 3.2.0.
This issue seems to only happen on this one computer. If I’m running a live link from 3ds to vantage. Turn off bloom. Once I hit render animation. Vantage reverts back to the default settings with bloom turned on. I’m using a Vray camera.
There was an issue in the older V-Ray builds where the settings reset when Animation Live-Link is started. Could you check if you are on the latest 7.40.04?
V-Ray 7 for 3ds Max, update 4.2
You can also update the Vantage to 3.4.
I have V-ray 7 update 3 DR2 (7.30.02 build 00000). I’ll update v-ray now.
I updated vantage 3.4 yesterday. No change
updated v-ray and it fixed the problem. thanks for all your help
Good to know that, thank you for the fast update.
