Blotchy Night Rendering
I’m trying to create an evening look… are there some tricks one can use?
there seems to be a lot of noise, especially in the front of the image, but also the image as a whole.
the lights are a simple box with a emitting material. will i get better results if i use enscape lights?
thanks
jorgensen
Hey @Jorgensen_dk , indeed, you should get better results when using our dedicated Enscape lights. You can try to replace the emitting materials in your project with our own lights, as this should already help with reducing the noise at hand. Let me know in case you have any questions regarding this procedure!
thanks demian i will try that.
jorgensen
There are also some artifacts on the ground that should be improved/solved in the next preview.
im getting this mess in the foreground for both renderings and animations.
i turned down the “Ambient Lighting”.
turned down Exposure.
changed out the “material emissive lights” for the “Enscape OBJ’s”
Hey @jsaravia we just released the mentioned new preview which will help to reduce/resolve these artifacts.
To acquire our latest preview, go into your Enscape About window by clicking the “About” button in your Enscape ribbon/context menu → Click “Visit download area” → Click the “here” hyperlink right in the first sentence below the “Download” button to get to our Preview download page → Download and install our latest preview.
Thanks a lot in advance!
Ewww - way worse than the last preview version:
Enscape-Setup-2.3.2.691-gc719ee7:
Enscape-Setup-2.3.2.420-gdeb9705:
Also the video export looks worse now, full of big GI splotches. Something is wrong with the current preview.
@Demian Gutberlet
i have the latest and greatest and i have also tried the previous version and im still having that problem.
Quick question, does the performance / capability of the graphics card affect things like the blotches?
Would a better graphics card produce a better result?
Thanks for sharing your preview feedback, we will incorporate that.
@paul_3 no there is no relation.
Thanks, I was hoping my splodges were due to poor hardware but now I know its poor meatware (me) :slight_smile:
Should be optimized in our latest preview 2.3.2.703-g2edb284
How can i fix this problem? Can someone help me with some settings?
@Andrei_2 Which version of Enscape are you using?
@Jonathan_Knoefel I’m using 2.3.2
@Andrei_2 Please update to our latest preview version 2.3.2.703-g2edb284. You’ll find the preview section via a link at the bottom right of our download area.
You can access the download area via our [About] button.
  1. Open About window and klick on “Visit download area”
  1. Go to the bottom of the download page an klick on “here” in the sentence about the preview area
  1. Check the preview version and download it
@Jonathan_Knoefel I did what you told me but the render is still the same.
Don’t use emissive surfaces that are very intense and tiny. Emissive surfaces that are very small and bright cause these kind of artifacts. Use artificial lights instead or in addition and your problems will be gone.
