This is a new problem I’ve started seeing in some of my renders. I’m getting blue dots. I remember the red dot problems and how to fix them, but this seems to be something different.
(The purple flash in the sky is due to a limitation with the VRay sun/sky in 1.49.24)
have the same problem, except mine are white and not as many though.
my guess was to increase the Hsph subdiv in the irmap, turned it up to 70, but did not help.
Now I am trying to render with an extra pass in irmap.
but now I remember there was an issue with the color correct pluginn, hope that that is not the case here, because I use it all over the place (not in hdri though)
Well yes… BUT… you said the purple flash was due to a limitation in vray sky for your build. purple/blue flash.. and now blue dots… me thinks they are related.
i experienced this in a test animation, but found that if i unchecked clamp output, the error dissappeared. I was getting a blue-ish patch similar to this at early morning / late evening times.
