Blurry/pixelated Render
Any suggestions on how to clean up the Renders when using a Dome light? Most all of the surfaces render really pixelated/grainy. I have the DPI set to max as well as the quality and nothing helps.
Hi Kraig,
Can you post some images for reference?
Noise might be caused due to lack of light in your scene. Have you tried playing with the EV and Dome light intensity settings?
Using the denoiser channel (Settings->Channels->Denoiser channel) could help you in case your scene is lit correctly.
Regards,
Ana
Kraig,
definitely give the denoiser a shot. It should clear up the noise you’re seeing. Also, is this the raw render, or did you need to adjust the exposure or brightness either in the frame buffer or photoshop? I ask because if the exposure for the camera in the camera settings is too low initially, it can cause some extra noise and splotchiness.
-Ben
This is the raw render.
Try the denoiser and see if that corrects your problem.
-Ben
