Bombs in max
I have a movie intro I am working on and I have a box and stuff that explodes…But the fragments that go everywhere suck…What else can I do? Can I insert something in their place?
Thanx
have you tried with particles? pflow does a good job with debris and stuff like that.
Get RayFire Tool or RayXPLosion…that’s some serious vandalism :stuck_out_tongue:
Regards,
Thorsten
Try using martin breidts mbfracture from here - http://scripts.breidt.net/ - it uses slice modifiers and noises to make better look fragments than something parray. You might need to run it a few times to get the results you want but it’s not bad at all - Pre break your objects and use bobos scene objects to particles tutorial here - http://www.scriptspot.com/bobo/mxs5/pflow/pflow\_\_Chunks\_Basics.htm and you should get better results. Maybe even have them spawn trails of smaller bits to give you more detail.
