Bongo animation bug - frame buffer controls are reset
I’m rendering a few animations this days per Rhino 6 and VfR4 and run in the issue, that the exposure settings are reset if the calculation of the animation is started. I have seen this issue at two different projects.
Only it helps to be fast and load the saved setup during the first frame is rendered. Could this issue be fixed please? Or will be no updates for VfR4?
-Micha
Hi @Micha
Do you mean Exposure Value is reset to the default 10 or the Advanced Camera Parameters? Either way, I was unable to reproduce the issue and render settings are preserved between frames.
Could you provide a step-by-step description how to reproduce the issue? Additionally, what type of animation is being rendered, view and/or object?
Hi @georgi.georgiev ,
attached a simplified project file.If you start a normal rendering than you can see the exposure frame buffer controls like at my screenshot. If the animation calculation is started than all settings at the frame buffer are reset. My animation are objects or object/view animations.
-Micha
PS: Could it be possible to be able to attach larger files here? Maybe 5MB limit instead 2MB only.
FrameBufferReset.zip (1.09 MB)
My bad for neglecting the detail in the title!
Kindly note that this behavior was resolved for V-Ray 5
Ah, good to know. I’m a little bit careful and still use VfR4 for complex projects. :wink:
Thank you.
