I ask me, could it be possible to switch between both denoisers if a rendering is done? Each of them has advantages and for example it could be great to save both results and combine the results in postwork.
I second that request. Would love to use both. It would also be great if I could dedicate a gpu to the Nvidia denoiser so that it doesn’t eat vram which I need for rendering. Using the denoiser with the gpu attached to the monitors wouldn’t be a big problem, right?
+1
Great idea. If I render complex scenes than I use my two 2080ti only and the 1080ti is reserved for the system display use only. Using it for denoising instead the 2080ti with heavy load could be help a lot.
+1
just catching up on Vray 5 and new frame buffer seems to be missing a few things. (frame stamp!?)
