Brick
How are you all making your bricks? I was using Omnitile, but it isn’t working on Windows 11 and I don’t think they have plans on updating it. I can’t find a download for Acme Brick anymore. They have an online version that doesn’t work. I tried Substance 2, but it is clunky as heck in MAX, and crashes often. I have been trying all day to make some bricks, which used to take me about 15 minutes.
I thought you had your method sorted for bricks, slicing up singles in PS etc?
Using those within Multitexture/Bercon Tile is probably still the best way at the moment,
although the inability to display properly is still an annoying issue, so I’ve
rendered out the result as a massive texture to overcome that.
I did, but I used Omnitile to create the pattern. I can use a single brick to arrange them in any pattern. Often I get the same brick but in different patterns.
Here’s a Bercon setup if it’s helpful.
It’s only basic, so you need to set up bump etc, but it does correctly display in the viewport, due to
some fiddling to make it so. Very unintuitive but it does work.
You can see my reference UK brick which I used to eyeball the Bercon dimensions.
BERCON BRICKS TEMPLATE.rar (263 KB)
You could also look at this https://www.quick-tiles.com/
I tried the demo and thought it showed promise.
OSL using this method
That looks awesome. Downloading niow.
Thank you. I’ll give it a try.
Thank you. I’ll check it out.
