I’m working on a project where the irrad map blows out to nearly pure white somewhere around 1700x1100 but renders perfectly fine at normal preview resolutions - say 850x550 or less…
I had the interior scene pretty much right where it needed to be and decided to render overnight at a higher res and print it to go over any final additions… The render showed up pure white.
So now I have the scene open and I can change to 850x550 and it works but if i set it to 1700x1100 it’s white… It’s not like this is my first interior or anything, I’m doing much of the same stuff I always do… I’ve gone over all the obvious stuff but fyi i’m rendering using irrad / light cache + show progress so I can tell on the first irrad map pass that everything is white… Really weird. There are no special materials or strange objects in the scene…
3ds max 7.5, XP Pro SP2, Dell Precision 470, VRay Adv. 1.47.03
Any suggestions?
