Bring VFB to front.
I would very much like it if the VFB pops up in front of all the other windows whenever I click the VFB button or the right click > V-Ray VFB button. So even when it’s open I don’t need to start minimizing other windows (material editor, settings, command panel, or whatever,…) to find my VFB. I hope there’s no Max limitation to implement, I think a lot of us would appreciate this.
Hi Ashley,
This has been logged as a request into our internal system under VMAX-10743. I’ll let you know when there are any updates on the matter.
Thanks Nikoleta, FYI Corona FB has the intended behaviour.
Another sidenote, please make sure the VFB is also brought to the front when clicking render, because I find myself looking for it, realizing it’s behind another window, so I can’t see what’s going on, unless I cancel first.
Yep, this is also noted in the request.
OMG you guys did it :slight_smile: . Thanks a lot! Quite suprised I found it by accident. You should’ve put it in the release notes, this is huuuuuuge :wink:
