Bringing Attributes to the Shader editor
Hello
Blender cycles and eevee have an ‘Attribute’ node that allows you to bring any attributes to the shader editor. What is the equivalent way of doing this with V-Ray?
edit: I’m using Blender 5.0.1 and VRay 7.20.01.
With geometry nodes, I only have access to the attributes if I store the attribute and apply the modifier, which is a destructive and undesirable workflow. Is this a limitation or is there a solution?
Below, on the left side, is how I’m trying to access the attribute with V-Ray using V-Ray User Color. Right side is Blender Cycles result using the Attribute Node directly plugged to the material output (no nodes in between).
The geometry nodes setup is the same in both cases.
We recently had a question about this so I added support for more geometry attributes types(Point/Edge/Face/Corner with most of the data types) and it will be available in our next release at the end of May. For the time being we only support Color/Byte Color in Point/Face Corner domain so in theory you should be able to get something similar if you use Color instead of Float as your data type in the Store Named Attribute node.
Thanks! That worked fine.
Any plans to also bring Instance and/or Spline domains for the next release? These two are strongly present in the procedural workflow.
It would also be helpful to have this information in the Documentation under a “Geometry Nodes modifier” tab or so (to avoid confusion with V-Ray Geometry Nodes).
I have tried to add support for per-instance attributes multiple times(mostly with hacks) but have failed every single time… I can get one or two levels of instance nesting working(i.e. geometry nodes instantiating other instances) but it always breaks with complex setups. It will require quite a big rewrite which I had quickly tried to do(and it worked for the most part), but I am not sure what else will break, so I don’t think we can do that any time soon. I haven’t looked at the Spline domain yet, but will see if we can do something about it.
