Seems to be working fine with the mentioned build from what I tested. What version of Deadline are you using? Does this happen with a particular scene?
We do not guarantee compatibility between config files from different versions.
Otherwise, the silent installation setup should be as follows:
1. Install V-Ray on one machine with “gui=0”
2. A config.xml file will be created on installation end
3. Use the config.xml file to silently install V-Ray on the other machines
The issue seems to appear when the “STDROOT” is different than the default location (C:\Program Files\Chaos Group\V-Ray\3ds Max 2020) when installing silently and using network rendering. It seems V-Ray searches the default location rather than the one assigned on install. What stable build did you make it function with the posted .xml? Otherwise, I’ve logged it as an issue (internal bug-tracker id: VMAX-10229) for developer analysis.
Update, had to upgrade to a new version, did a new config file from scratch and when deploying it gave the same error. Then I edited the STDROOT as you said and it worked. So something is broken on the installer when doing the .xml for the first time.
