Brothers love: a residential project
Interior
Exterior Shots
Hello everyone, this is my design for my brothers house here in the philippines. I guess this is done, however ur comments are sill greatly appreciated and C & Cs are welcomed. Thank you so much and god bless.
Nice renders! Could you share you lighting (exterior) & glass settings? They look great!!
Hi zapcat, thanks for your comment.
here are the settings that i frequently tickled in this project. if u need more info just mail me. :slight_smile: hope this helps.
BTW: special thanks to carlo serrano for the tips.
great work! I noticed a lack of GI details in your image though, and your settings confirm it. Setting your HSph subdivs to 100 is great and all, itll get rid of splotches, but setting your Interp samples to 75 just blurs the crap out of your GI shadows negating your really setting your HSph samples so high.
Heres an image illustrating the issue:
This is a greeble scene rendered at 100,20 and 100,75. all other settings are the same. They were taken into photoshop and set to difference. As you can see theres a fair amount of difference in color at the corners and edges. I adjusted contrast a little to make the effect more evident.
Hope that helps ya some.
yeah i agree with percy … and it shows in the images…also you are not letting any light through that glass of yours… is there a reason for that ?
Where did you get your HDRi image?
some of the settings in vray are difficult to understand and frankly counterintuitive to someone who hasn’t used it alot. I think its especially evident in the Interp samples. You always think that when it comes to samples, more is better, so that upping thse interp samples would be a good thing.
what ever happened to the mouseover help you could get by placing your mouse of the spinners?
Percy, for some reason the image you posted is just showing up as a big black square, any ideas?
lol, i think its supposed to be a big black square with white streaks showind the difference between two images rendered with one parameter changed.
I dont know what is a “greeble scene” though, so percy could you please post both images that you used for difference?
sure… kinda figured Id have to anyways.
I see what you mean, the second one seems to ‘float.’ Are you using Max 6? I didn’t know Greeble was compatible with it.
yes I am and yes greeble is out for max 6. get it at www.maxplugins.de
hi,thanks for the tip percy. i admit that i still have alot to learn esp. vray and its settings.
To everyone,thank you so much for participating. :slight_smile: cheers to all
