BTH-recent render 2...
hope you like it…
Re: BTH-recent render 2…
Well I like it!
Specially the leather, very realistic. What Highlight/Reflection glossiness did you use?
Ok I give up, how did you achieve such good UV mapping in sketchup… for example the blue chair material.
Great renders :wink: Only some corners looks very sharp.
Top notch render.. one of the best.
;D really really great! one of the best ive ever seen.. keep it up!:slight_smile:
Excellent renders, congrats!
thank’s all.
-40th:
I used this material for leather http://www.mediafire.com/?g4ziqng4jkr
-EDONK:
to apply material to the surface is not flat, I use texture-Projected (right-click on the material). I adjust the UV in SketchUp Materials as usual. with vray 01.05.30, I’m using the UV is matched.
add an image with a white wood…
They look great, I like the last one which is almost ‘dollhouse like’ in realism.
These images are great. The amount of detail is stunning and the lighting is perfect…my only critique is the wood texture in certain areas. I really cant put my finger on exactly what it is, but it just seems realistic in some parts of your images and a lot more fake in other parts. Dont get me wrong, the wood looks good, but I think if there was a little more control there, these images would be pretty much photorealistic. Its a bit picky, especially with how great these are. Good work.
steelers05 : “wood” is really not good, I will try over the next. thank’s for CM.
thank’s all.
Thanks tranganhhp.
Can you share the cushions, they look great :wink: !
Btw what is the poly count for this scene? It looks very high detailed…
40th: you want to share my leather sofa?
wowwww it so real !!!
so beautiful
I’m your fanclub
HA HA Ha
great man can you post how long you render the image and what visopt you use .The coach looks greate is it made by you.Great man keep going
bechura:
average time of each image is more than two hours.
this is the basic settings to use for this scene (version 01.05.30)
http://www.mediafire.com/?tzik1aqmmzi
excelent renders, specially the fireplace ones, whant type of lighting did you use?
NEKTARES:
I used map + transparency for fire and use a omni lights (with decay = inverse, subdivs = 15 …).
I do not use “emissive” because lighting is not well.
thanks man i will use your settings ,your renders look so good .
I really like the cushions on the sofa, can you share them? (that was my question)
