Bucket and Progressive Samplers' Analysis
You mean lowering the ray bundle size improved the cpu usage during progressive? Did it improve render time? Interesting. I had always assumed a higher bundle size would be more efficient. I guess I had better do some tests.
Fair warning: usage != speed.
Lowering RBS may just initiate more data transfers across the system’s buses.
Ensure you benchmark the rendertime.
Also, there is likely a specific threshold for each CPU, and scene, below which things worsen, even considerably.
Mileage is going to vary quite a bit.
Precisely my point about asking if it improved render time.
Just because the cpu is doing more doesn’t mean rendering faster.
Why does progressive seem to have much more idle time on the cpu cores? Would be cool if that could improve. I think now that bucket has the automatic subdivision that fixes last bucket syndrome it is usually faster. But, with everything, YMMV 8)
It doesn’t for me, generally.
It does if the progressive caustics engine is on, due to the time it takes to gather and make sense of the caustics’ data between passes.
No caustics other than the default GI based caustics.
On the entire farm when using Progressive I frequently see the CPU usage well below 100% Sometimes down in the single-digit percentages for periods between pass updates I think. So I end up having to run multiple instances of Max to maximize usage. With Bucket it is almost always 100% these days (thanks to the Last Bucket Syndrome fix!).
