Max 7.0 + SP1
I use precalculated IM for animation.
I render IM with option “Incremental add setting”. This option works correctly if i render in single renderstation and not use network render. And all ok if i not reloaded 3dsMAX. If i save scene and load again - IM include last frame only.
I don’t understand why if i use netrender (backburner) my IM include only last frame of sequence.
For example,
i need IM for 1,90,270 frame. Final IM include only 270 frame. All others frames was deleted.
is this really a bug? seems to be this is natural. al your machines are saving to that same file so some of them will be writting over it. all machines dont contribute. each does their own IMAP. and dont try DR that doesnt work either. Your best bet is to setup different IMAPs for each computer then join then in the IMAP viewer
