BUG: contrast less than 1 not possible in corona cam tag
Hi
this seems a BUG in cam:
in vfb i can set the contrast less than 1, like to 0.7, but in camera i cannot set this, it always switches back to 1 in each new render or when i though any camera setting.
for certain work flows, in special with very low HC, it is needed to also use lower than 1 contrast.
it would be great to allow allcontrast values also n the cam,not only in vfb settings
thanks!
Stefan
it seems that the range is incorrect in the Tag (1-99). We will look into it.
Thank you for reporting,
Jan
(Internal ID=646183658)
