bug- error when rendering but second time sometimes work
I have encountered a bug in a few un-related files:
the render doesn’t work on the first time, there’s an error reffering me to the log but when I render again, sometimes with a bit of camera shift it does work.
Sometimes it will just crash.
I tried to render parts: I copy-paste every single object in my model ( it’s a heavy model: 30 mb) to another file and there it does work. but all the object together seem to cause a problem.
I haven’t assign any any v-ray textures yet and used every debugging tool there is and purged the model.
the error log said:
=========System Information=========
platform = win32
country = Israel
language = Hebrew
About to make our qapp
after make qapp
Made it after UIManager.initialize
C:\ProgramData\ASGVIS\Python26\Lib\site-packages\Ft\Xml\InputSource.py:346: DeprecationWarning: functions overriding warnings.showwarning() must support the ‘line’ argument
FtWarning, 2)
FtWarning: Creation of InputSource without a URI
Entering renderArchive
About to start readArchive - C:\ProgramData/ASGVIS/VfS/current_skp.xml
54.190000 seconds is how long it took to read C:\ProgramData/ASGVIS/VfS/current_skp.xml
0.300000 seconds is how long it took us to correct the file paths for all external texture file references in the scene.
(to ensure this process goes as quickly as possible, please be sure all references to external texture files are correct prior to rendering)
Traceback (most recent call last):
File “C:\ProgramData\ASGVIS\Python26\..\VfS\ASGVIS\vrayplugin.py”, line 215, in add_to_renderer
vray_param = param.to_vray_param(renderer)
File “C:\ProgramData\ASGVIS\Python26\..\VfS\ASGVIS\vrayplugin.py”, line 92, in to_vray_param
return self.value.to_vray_param(self.name, renderer, final_gamma )
File “C:\ProgramData\ASGVIS\Python26\..\VfS\ASGVIS\vraytypes.py”, line 348, in to_vray_param
return PyVRay.VUtils.DefStringParam(name, self.to_vray(renderer))
TypeError: argument 2 of PyVRay.DefStringParam() has an invalid type
File “C:\ProgramData\ASGVIS\Python26\..\VfS\ASGVIS\vrayrender.py”, line 328, in render
self.addAssetsToRenderer( self )
File “C:\ProgramData\ASGVIS\Python26\..\VfS\ASGVIS\vrayrender.py”, line 102, in addAssetsToRenderer
ref.plugin.add_to_renderer( self )
File “C:\ProgramData\ASGVIS\Python26\..\VfS\ASGVIS\vrayrender.py”, line 408, in renderArchive
self.render()
I would love any help- I can’t seem to make it work :frowning:
btw- all the su textures are in English, I found that when written in Hebrew it doesn’t show them and causes a bug.
Re: bug- error when rendering but second time sometimes work
does the scene render if you enable “override materials” in the Global Switches section of your render options? If it does, then the issue is either with materials or textures. We have fixed a few of these types of issues in our latest beta if you would like to try it out, just head over here to sign up: http://forum.asgvis.com/index.php?topic=7679.0
