Not sure if this is something you intended or not.
Frozen geometry renders as if its still visible. From the utils menu if you tick the geometry off` it still renders but slightly odd, maybe without textures ?
anyway.
Why shouldn’t frozen geometry be rendered?
if you have hide frozen geometry tick box on then its invisible in the viewport. Other render engines dont render that geometry so why should Corona ?
Ah, ok, hidden and frozen, didn’t get that.
I forgot to say it that`s why. ![]()
Not a huge issue just a bit odd.
where exactly is the “hide frozen” checkbox?
In the display tabjust above the frozen object rolout. its labelled hide frozen objects` without it being ticked objects are visible in the viewport, with it ticked they are not visible.
Fixed
