We have this super critical bug, where, whenever I press render the frame buffer window is visible for like a second and then disappears. If I press the frame buffer window button again, a frame buffer window opens but without any rendering and the status just say “plugins finished loading”. If I press render again, the same thing happens over.
I think it has something to do with our rhino file, since it doesn’t happen in a new rhino window. The problem: I can’t copy/paste stuff from one file to another, since you can’t copy Cosmos assets and lights by the looks of it, only geometry and materials.
The same file also refuses to export as a vrscene file. You press it and simply nothing happens.
What can we do?
ps: one bug I noticed that might be causing some of it: if you alt-drag a light in Rhino, it will be duplicated in Rhino, but not in the V-Ray assett editor. Then if you select the light in the assett editor and click “select in scene” it will basically select both lights in Rhino and think they are both the same light.
Has anyone had this bug? How can I fix our seemingly corrupted file?
